Presentación dCS Vivaldi + Thrax audio en WERNER.
+33
Giovani66
Dumbo
sonobull
Joan Orti
dukekore
Radeon
samtrom30
Cons
Hamilton
Jesús
jmpg
patorrents
altafidelidad
carrey
Tomcat
Narayan
elchicodelasválvulas
Pedro
rodrigues
Konstantin
delt
yasduit
gaby
Valvulator
YING
KILLMIK71
37 participantes
Página 9 de 11. Precedente  1, 2, 3 ... 8, 9, 10, 11  Siguiente
Presentación dCS Vivaldi + Thrax audio en WERNER. - Página 9 Empty Re: Presentación dCS Vivaldi + Thrax audio en WERNER.
Mensaje  Rebombori Dom 28 Abr 2013 - 23:42
Pues yo si lo veo y dice "hasta 70 W a 8 o 4 ohmios"
Cantidad de envíos : 12198
Localización : Alacant
Mensaje  Mordecai Lun 29 Abr 2013 - 7:58
carrey escribió:
altafidelidad escribió:Aqui el manual de usuario...
http://www.thrax.bg/pdf/Operating_Manual_Spartacus.pdf
Segun aqui,70 watios son los que pueden dar...
No obstante, las noté sin pegada, muy fofas
Algo pasa que no me deja ver el enlace.
Tienes el Acrobat Reader instalado en tu ordenador?
Cantidad de envíos : 3659
Mensaje  elchicodelasválvulas Lun 29 Abr 2013 - 10:23
Esta parece ser su filosofía:
Technology
Tube amplifier design has over 100 years of history. It started with the simplest possible amplifier which is shown below (fig "A"). This is a `single ended’ common cathode amplifier, referred to in the industry as Singe ended triode or SET. This type of gain stage is the basis of our amplifiers and is recognized for its superior sonic signature.
Why do we use triodes?
Audiophiles have been led to believe through published measurements at maximum output power and uneducated reviewers that single-ended triode amplifiers produce vast amounts of harmonic distortion. As a matter of fact triode vacuum tubes are by far the most linear amplifying devices in existence today. They produce the least amount of distortion, and that distortion is predominately second harmonic, which is the least obtrusive type for the sound. By contrast, pentodes produce greater distortion, and the third harmonic tends to dominate. A transistor looks at best like a very bad pentode.
Why the output stage is push-pull and what would an SE be?
To state the obvious, a single-ended circuit must operate in Class A1 or A2. A push-pull amplifier may be Class A1, A2, AB1, AB2, B1, or B2. Class A indicates that each output tube handles the full cycle of the audio signal, while AB and B allow some of the devices to cut-off during a portion of the cycle.
Subscript "1" indicates that no grid current is drawn by the output tube, while subscript "2" indicates that the output stage enters the grid current region of operation. In the grid current region, the impedance presented to the driver stage is abruptly lower, and drive power is required, not just drive voltage.
The grid current region tends to be rather non-linear load for the driver and most designers will avoid it.
Single-ended and push-pull circuits may be built with triodes, beam power tubes, pentodes, or the latter two in ultra-linear mode. We use exclusively Class A push-pull circuits for our output stages, there is a natural cancellation of even-order harmonic distortion products in this topology. The cancellation is not complete, but it would be unusual to see large amounts of second harmonic distortion from a push-pull circuit. Note that a push-pull circuit has no significant ability to cancel odd-order distortion products. If low distortion performance is required, one must avoid the generation of odd-order harmonics in the first place. A good triode tube meets this requirement.
In single ended operation there is no mechanism to naturally cancel harmonic distortions and available power output is greatly limited. The full DC current for the output tube(s) flows through the transformer primary and strongly magnetizes the core of the transformer. Thus, much of the core's ability to couple the audio signal is used up by the non-audio DC current, and causes the core to saturate asymmetrically with audio signals Adding parallel output tubes for more power directly increases the DC magnetization current, thus exacerbates the distortion problem.
To deal with this an "air gap" may be introduced into the transformer core. In most cases also a greater amount of core material is used, which in turn makes the whole unit larger. By increasing the size of the coils we soon become limited by parasitic capacitance and leakage inductance affecting the bandwidth of the transformer. The final result is either a higher degree of distortion (all harmonics with the second dominating, increasing with decreasing frequency), a measurably peaked frequency response, or both. As observed the best sounding single ended designs rarely reach above 20W and is practically impossible to manufacture a transformer of utmost quality for more than 80W in single ended triode operation.
Since the distortion in the single-ended transformer is asymmetrical, a system based around this type of amplifier might be more sensitive to absolute polarity.
Same problems are true for the push-pull transformers but there the power limit for the same size transformer is 4 times higher.
Assumptions lead to wrong conclusions.
Traditional theory gives feedback high marks. Consider that when the "error" signal is fed back into a non-linear amplifier, it multiplies the distortion order. For example, if an amplifier naturally produces second harmonic, feedback will create a second harmonic of that second harmonic, which is the fourth harmonic. If the basic amplifier has second and third, the fed-back amplifier will contain second, fourth, sixth, and ninth. As is well known, the higher orders of distortion are far more objectionable to the ear than lower orders, and odd orders more offensive than even orders. Thus it may be possible to lower the level of distortion products and still have the distortion be more audible.? The application of negative voltage feedback also reduces an amplifier's measured output resistance, i.e., it raises the "damping factor." Here again, the measurement fails to capture the essence of things. In the case of a feedback amplifier, better control of speaker motion is said to occur because the speaker's excess motion creates a voltage (the back e.m.f.) which enters the feedback loop via the amp's output terminals. The amplifier then acts in a manner opposite the error signal to correct for it. However, like many theories, this is an oversimplification and, in practice, the opposite result may be obtained. Quite often the motion of a speaker's voice coil former may not match the acoustical output due to cone break-up and the fact that the motion of the coil former is being sensed by the voice coil which is a reactive element with phase shifts and delays. On top of that the back e.m.f. passes through a cross-over network, which will again alter phase and frequency relations. By the time the error signal reaches the power amplifier it is arguably an erroneous error signal. As the power amplifier attempts to correct for this signal, it may actually do the exact wrong thing with respect to the speaker's acoustic output.
Small-Signal Distortion in Feedback Amplifiers for Audio
Bring theory to practice – no feedback.
It is logical that a signal passing trough and amplification stage will have some distortion added to it. (In our case this will be almost only second harmonic.) Passing trough the next stage we will add distortion to the distortion generating a minimum amount of fourth order distortion and so on. (Pretty much like the effect of feedback described above)
Consider now the following: the usual preamplifier (tube or solid state) has 3 stages (input buffer, gain stage, output buffer), then the simplest power amplifiers have 4 stages (input, phase splitter, driver, output buffer ). And all this is dependent of the signal amplitude via an extremely nonlinear function.
In order to minimize this effect the preceding stage of any amplification stage should have at least 2-3 times lower distortion than the latter. (Would that be possible when we have 7 stages in the signal path?) Minimizing the number of stages reduces drastically the order of distortion and its inter modulation products.
The sonic result is vastly improved transparency and speed.
Our products feature the minimum sensible number of stages implemented with the most linear devices possible operating in the closest to theoretically perfect operating conditions achievable.
Result? You be the judge!
The power supply concept.
Amplification stages are only half of the story. As seen on fig 1 the power supply is represented by a single capacitor. This assumption alone has ruined many beautiful designs.
In theory a large enough capacitor is as close as you get to the theoretically perfect power supply. Well in practice is not so! You have a rectifier and the mains supply connected to it. For every cycle of the mains you have two things happening. You charge the capacitor trough the diodes and the mains transformer for a limited amount of time by connecting it to the mains supply with all its noise and garbage and then you discharge it tough the amplifier and load until the next charge cycle. So your power supply is constantly varying its value and for a portion of the time is connected directly to the polluted mains line. (don’t forget the fact that this capacitor is part of the signal loop!!!)
And this seems to be acceptable for all electronic design gurus?!! Now analyze this.
Here is an example of a good amplifier design and it’s power supply. By looking at the whole picture you see a coil (choke) separates the reservoir capacitor from the signal capacitor, thus preventing any noise from the mains reaching the signal capacitor and as a side effect keeping a constant voltage across it.
It is very unfortunate that no currently available commercial products feature similar topology. On first glimpse it looks simple yet it does all that is required by the psu to approach the theoretically perfect with minimum component count.
Clean power, clean background and no IMD.
A further improvement to the above example is the use of a choke loaded rectifier. This reduces the current fluctuations (pulses) needed to charge the reservoir capacitors and stops the diodes switching noise from entering the signal loop. Although high frequency interference noise is not audible its inter modulation products from the interaction with the audio signal are very noticeable. So avoid it at all costs.
Now leap forward a hundred years and implement this technology with the most advanced components and circuits possible and you are pretty close to perfection.
The extra and often overlooked paths off the signal.
In all directly heated tubes the signal current passes trough the cathode of the tube with is specific resistance generating AC voltage across it. Its amount is dependent on the tubes used and operating conditions but it is ALWAYS there.
In almost all implementations today there is a large size smoothing capacitor across it producing a practical short circuit for the AC signal. This is justified by the designers in order to have a stable DC and no hum in the filament, but it ruins the operation of the cathode in ac.
The simplest solution was implemented again many years ago, it is a simple choke in series with the filament. This is the simplest possible solution providing separation of the ac path and the dc path. Simple yet almost always overlooked. It is practically impossible to make a good enough inductor with reasonable size and cost to tackle the task, but a modern circuit called a gyrator can achieve the same effect.
The many sensors in the amp.
Now that we have designed a simple, yet sophisticated amplifier building it in practice to perform to design specifications presents a number of issues on its own. One of the most overlooked aspects of design is the mechanical construction and component vibration control.
As you probably know sound is recorder by sensing the sound pressure with microphones. There are quite a few types of microphones but they fall in two main categories: electromagnetic and electrostatic. Electromagnetic types work by sensing the variation of a magnetic field and logically the electrostatic work by sensing the variation of a static electric field.
Well guess what, every wire in magnetic field is an electromagnetic sensor. Does not matter what the cause of magnetic field variation is (the wire vibrates in a constant field or the field changes) you have a parasitic signal entering the signal path.
Each capacitor is in practice also a microphone superimposing the environmental vibrations on the voltage across it. This effect is only dependent on the mechanical construction of the device itself. (Defining how microphonic it is).
This applies to vacuum tubes as well as to solid-state devices like transistors.
The only way to reduce those effects beyond the threshold of audibility is by proper mechanical design of the equipment layout and chassis and the selection of components with correct construction and not only electrical parameters.
Fighting noise and emi/rfi.
another source of impurities that might enter the signal path comes from the air. Known as EMI/RFI (Electromagnetic interference and Radio Frequency interference). This is the effect of every piece of wire working as an antenna for airborne electromagnetic waves. Those get rectified and produce signals the interaction of which with the audio signal produces inter modulation products and are very audible. Some of you old enough that remember AM radio and it’s specific background noise, this is what you get in your amplifiers. Quite often the source of this interference is within the chassis of the device itself (bad PSU design, transformer and rectifiers) and more often than not enters through the power supply or other attached wires (noisy power line). (sound of cables ….)
Balanced??!!
Here comes a way of reducing induced noises in the interface between components.
Transformers stop many of the polluters from entering the signal path by the nature of their operation and construction.
A good description of how and why is available in the white papers at: www.jensentransformers.com
Isolated "cells".
Using transformers to separate each gain stage of the system from the outside world is a good means of securing clean signal handling. Resulting in high s/n and much more expressive contrasts in the music nuances and timbre. This is also one of the reasons why our amps have clarity unheard off before.
Power – how much is enough?
This could be argued a lot. But here are our observations: At normal listening level (approaching and exceeding a bit the natural level of sounds) The peak SPL reaches 110-112db. So a high fidelity system has to achieve this in the listener’s room. On average the listening volume is 86-93db, the higher levels being peaks in the music program. Consider also that the average noise level in a listening room rarely goes below 24-26db SPL. Now put speaker efficiency on the equation and you will get something like that:
If your speakers are "modern" high performance super duper design with 82-87db/watt sensitivity look for a power amp capable of 400+Watts. (most probably class D types)
If you have been more sensible and opted for a speaker with 88-93db you don’t need more than 100w to enjoy the full scale of orchestral pieces and the selection of fine solid state and Tube amplifiers the market has to offer.
If you have your house built around a pair of full range horns with 108-112db/w you might consider a "spud" tube amplifier with 3-6W to rock the neighborhood. (this is a single tube amplifier)
Any other combination will not lead to the desired result.
Handling digits.
There are three different aspects to be discussed in DA conversion.
First is the Conversion process.
Second are the processes before conversion takes place (DSP)
Third is the timing of it all or clocks. There are multiple books on each of the above subjects, so don’t expect an in depth analysis but more a guide for what to look for in a DAC.
Multibit vs. Single bit (bitstream) converters. Google it. There are 1000s of pages, but it comes down to this: Multibit when correctly implemented is better, but far more difficult to make at high resolution. Hence cost is prohibitive. There is no single chip solution as of today! There were some 20bit converter chips (burr brown) in production and they have legendary status among users. Even today there are new designs coming out around the first Philips chips (20 year old) claiming audiophile performance and unbeatable sound. We have taken the road of multibit converters and have requested MSB to develop a version of their discrete DAC chips to meet our requirements. You can read about their principle of operation on the MSB site.
The hype about high sampling rates and the argument for non-oversampling dacs.
Well in order not to enter this argument we decided to support both.
We support high sampling rates up to 384kHz accommodating all existing formats, yet we are not bats – it is the inter modulation and filter characteristics that are audible not ultrasonic signals.
Resolution of our converter is up to 26bit fed with a 32bit word.
It means that we process and covert the incoming data without rounding and re dithering.
Again to overcome all arguments and to accommodate for the user preferences we support multiple options for up sampling re-clocking and digital filtering.
Any signal processing on a 24bit word of data will generate extra data. Almost all other dacs and processors will truncate the data back to 24bit. We let it flow at 32bits keeping all information as insignificant as it might be. Otherwise those errors accumulate and after 3-4 processes (re clocking, up sampling, dithering, energy filters) those become significant and are clearly audible.
Apart from the data fed to the converter the other major influence is the time at which the conversion happens. You can google jitter and will be swamped with lots of meaningless pages. In essence you are interested in the cleanliness of your clock and short-term stability, also known as phase noise.
You will see companies offering rubidium, atomic, gps locked, tourbillion and hourglass clocks out there but a properly designed and manufactured quartz oscillator is pretty much unbeatable for audio. Having said that please note that less than 0.1% of the ones we have seen are up to standard. The most interesting property for us is low phase noise at the very low frequencies and high s/n of the clock signal with no distortion. (at present in development).
All conventional DACs require buffers and filters. Those are always implemented with Opamps. (even discrete opamps) They isolate the dac from the output and sum the outputs of multiple dac chips, convert I to V and other tasks, but it does not matter haw good they are, they always severely limit the sonic performance of the dacs. Whatever you have done up to that point performs at the quality level of the opamp used. (isn’t this sad). Fortunately on multbit dacs with low impedance resistor ladder (it has to be low resistance to keep the noise down) you can take the output directly from the conversion resistors. Taking it directly we can sum the multiple dacs with a transformer with multiple primaries and by taking the output from the secondary of the transformer we have a complete solution.
Isolation of the output from the dac, stopping any high frequency content passing trough the band limited transformer avoiding IM distortion and summing out of phase removes all common mode noise and artifacts you can call it „the magic of coils".
Why no body does that – and why they do only a partial job.
Transformers don’t measure that well. They have limited bandwidth and rising distortion at high levels and low frequencies. All those shortcomings are true, but would seem to be substantially better performing in dynamic conditions than ANY op amp. The effect is jaw dropping not subtle.
What you pay for and why it is a bargain.
As explained above our products are very complex and use very special parts at substantial procurement cost. The price of our products reflects directly the cost of materials involved in its manufacturing and the time required to assemble them. All technology development is funded by other activities and the knowledge is reused in the development of other solutions and products.
As specific R&D is undertaken to further the performance of the existing products and to optimize manufacturing process, this should bring better products without raising cost.
Cantidad de envíos : 3844
Mensaje  carrey Lun 29 Abr 2013 - 16:06
Gracias chicos, pido disculpas, el enlace si que funciona, lo que pasa es que tarda un poco en descargar y yo no le daba el tiempo suficiente.
En cuanto a la etapa sigo pensando que es imposible que de 70 vatios y maxime trabajando en clase A como parece que dicen ellos.
He mirado la hoja de datos de Emision Labs y dice que la válvula trabajando en circunstancias normales da 18 watios, así que multiplicado por dos serian 36 watios, eso en paralelo, si lo hace en push-pull serian algo mas pero vamos no 70.
carrey
carrey
Cantidad de envíos : 896
Edad : 77
Mensaje  carrey Lun 29 Abr 2013 - 16:15
Ufff veo que al enviar el correo me salen letras mayusculas y traduce frases, que cosa mas rara, no entiendo nada shock 2 shock 2
carrey
carrey
Edad : 77
Mensaje  altafidelidad Lun 29 Abr 2013 - 17:28
Simplemente me he remitido a las especificaciones del fabricante. No obstante, si la potencia total de cada etapa estuviera por ahí, sería muy justito para mover las pantallas asociadas... Pero repito que a nosotros nos parecieron con poca pegada...
altafidelidad
altafidelidad
Cantidad de envíos : 777
Localización : www.altafidelidad.net
Fecha de inscripción : 08/05/2011
http://www.altafidelidad.net
Mensaje  elchicodelasválvulas Mar 30 Abr 2013 - 22:42
Me escama ver tanta potencia asociada a una válvulas, además está la mezcla de Clase A y Push Pull hmm
Y que suenen fofas,....... me da que el diseño/construcción de los trafos no está a la altura. Pero no quiero ser malo Smile
Por cierto, ¿cuanto cuesta la pareja de Spartacus?, me imagino que bastante.
Mensaje  samtrom30 Miér 1 Mayo 2013 - 3:54
Una interesante vista interna del dCS Puccini U-Clock (4800 € [unas 800.000 de las antiguas pesetas]), donde se puede ver lo muchísimo que el fabricante ha tenido que trabajar para diseñar y construir tan excepcional componente (de ahí el precio).
Cabe señalar que, para que este componente rinda al máximo de sus posibilidades, es necesario, imperativo, asociarlo con el cable de red JPS Labs "DIGITAL AC" (350 €), también comercializado en su día por el mismo importador, a pesar de que éste era perfectamente consciente de que no era más que un cable EUPEN IMU-13 / ES 201 de 30 € (comprado al por mayor) reenfundado y reetiquetado por JPS Labs.
Presentación dCS Vivaldi + Thrax audio en WERNER. - Página 9 3007d1355066423-best-usb-spdif-converter-dcs2
samtrom30
Cantidad de envíos : 342
Localización : ESPAÑA (Barcelona)
Mensaje  altafidelidad Miér 1 Mayo 2013 - 9:29
elchicodelasválvulas escribió:Me escama ver tanta potencia asociada a una válvulas, además está la mezcla de Clase A y Push Pull hmm
Y ademas, lo peor es que viernes se bloquaron y sabado tambien. Mal diseño?
altafidelidad
altafidelidad
Mensaje  altafidelidad Miér 1 Mayo 2013 - 9:36
samtrom30 escribió:Una interesante vista interna del dCS Puccini U-Clock (4800 € [unas 800.000 de las antiguas pesetas]), donde se puede ver lo muchísimo que el fabricante ha tenido que trabajar para diseñar y construir tan excepcional componente (de ahí el precio).
En epocas anteriores donde no teniamos el acceso a toda esta informacion - preinternet - es aquello de ojos que no ven ....
Pero en la actualidad, que te tiras un pedete en BCN, a los pocos segundos en Australia lo "oyen".
El daño que está haciendo este tipo de actuaciones de gente sin escrupulos que aun se creen que todos los aficionados de este sector son/somos tontos.
altafidelidad
altafidelidad
Mensaje  papaito Miér 1 Mayo 2013 - 11:18
No parece que se hayan esforzado mucho, la verdad. Por este precio la placa del fondo deberia ser de oro de 24k. Claro que mientras haya incautos se seguiran vendiendo evil 3
Cantidad de envíos : 10697
Mensaje  Noncondition Miér 1 Mayo 2013 - 11:25
El efecto, realmente impactante, de verlo todo vacío, seguro que lo desmerece más de lo que debiera, al componente. dCS tiene una trayectoria larguísima en el campo profesional, y este o cualquier otro componente, no son cualquier cosa. Otra cosa es el mercado doméstico y el debate ya agotado de si las cosas valen lo que cuestan.
Digo yo.
Cantidad de envíos : 14252
Mensaje  César Miér 1 Mayo 2013 - 11:35
No se trata sólo del aspecto vacío, no hay atención al detalle ni mimo en su construcción, por ese precio se debería tener más cuidado el tema eléctrico, (cableado, IEC), por ejemplo, aunque no tenga la mínima importancia, pero EMMO supondría que el fabricante se preocupa por ofrecer lo mejor a sus clientes, máxime cuando abaratar costos no procede a tenor de sus precios.
Cantidad de envíos : 7636
Mensaje  papaito Miér 1 Mayo 2013 - 11:43
Noncondition escribió:El efecto, realmente impactante, de verlo todo vacío, seguro que lo desmerece más de lo que debiera, al componente. dCS tiene una trayectoria larguísima en el campo profesional, y este o cualquier otro componente, no son cualquier cosa. Otra cosa es el mercado doméstico y el debate ya agotado de si las cosas valen lo que cuestan.
Digo yo.
Lo siento Ramón pero estas pelis, actualmente, ya no cuelan a menos que se quiera vivir del nombre de la marca.
Abraçada
Mensaje  Noncondition Miér 1 Mayo 2013 - 13:06
Todos estos viven del nombre de la firma en el mercado doméstico, donde rentabilizan sus cuantiosas inversiones en el sector profesional: dCS, Emm Labs, Nagra... Luego vamos - van - los que pagan por ello y todos contentos.
Abraçada.
Mensaje  elchicodelasválvulas Miér 1 Mayo 2013 - 13:55
jajajajaja, concepto mal planteado: " o es demasiado chasis para tan poco software, o poco software para demasiado chasis" Very Happy
Ahora en serio, hay cosas que me joden: casi un mes y más de doce páginas hablando de una demostración, que a pesar de los conocimientos-supuestos-, sala-buena- y equipo -25.000.000 millones de las antiguas pesetas, ahí es nada-, no estuvo a la altura de lo esperado, (dejando aparte zarandajas, como el número de asistentes por demostración, rodaje, sinergia, o el bueno de Danglá andando por ahí).
Mientras, otras demostraciones-propuestas-, sin tantas pretensiones, mucho más baratas, sencillas....; y ni un triste comentario a cerca de ellas, y me hubiese gustado, tanto sin fuese positivo como negativo.
Dos cosas:
O los españoles somos wallbash wallbash .
O hay un tinglado montado sobre intereses, que van más allá de la aficción, donde participan todos los eslabones de la cadena, desde el fabricante hasta el aficcionado; donde importa más el impacto mediático,(buen sustento siempre para el HiEnd, sobre todo si hay pasta por medio), que el fin último que es la música reproducida; y para "muestra un botón", que es este mismo hilo. Sencillamente, mi no entender! Wink .
He tenido que sombrearlo, para que se lea bien!, por cierto por si alguno se pregunta que otras demostraciones son esas, me estaba refiriendo a por ejemplo la de Brokeraudio de este fin de semana pasado.
No sé al final, creo que aparte de la música perdemos todos.
Bueno sólo es una reflexión de las mias, así que nadie me salte al pellejo Very Happy
Mensaje  Noncondition Miér 1 Mayo 2013 - 14:22
Es muy fácil: ¿ ha ido alguien a lo de Brokeraudio ?; si es así, que lo diga y lo comentamos. E igual con cualesquiera otras demostraciones. Se ha hablado de lo de Werner, por que tenía mucho interés, por muchas razones. Por otra parte no creo que los aficionados de aquí seamos menos listos que los de fuera. Lo que pasa es que tenemos menos posibilidades evil 3 .
Mensaje  Rebombori Miér 1 Mayo 2013 - 14:38
Noncondition escribió:Es muy fácil: ¿ ha ido alguien a lo de Brokeraudio ?; si es así, que lo diga y lo comentamos. E igual con cualesquiera otras demostraciones. Se ha hablado de lo de Werner, por que tenía mucho interés, por muchas razones. Por otra parte no creo que los aficionados de aquí seamos menos listos que los de fuera. Lo que pasa es que tenemos menos posibilidades evil 3 .
Shocked
A ver, que yo ya me he perdido...
¿Qué le pasa a Brokeraudio?
¿Qué nos pasa a los aficionados de aquí que tenemos menos posiblidades que los de allá?
Explícate Ramón, que en estos días de medio ausencia, igual me he perdido algo.
Mensaje  KILLMIK71 Miér 1 Mayo 2013 - 16:54
Alguien de los que critican el puccini clock lo ha probado en su equipo?
KILLMIK71
KILLMIK71
Cantidad de envíos : 2520
Mensaje  samtrom30 Miér 1 Mayo 2013 - 17:17
KILLMIK71 escribió:Alguien de los que critican el puccini clock lo ha probado en su equipo?
No me hace falta. Por más efectivo que fuese, yo por un chasis que contiene AIRE en un 75% de su interior, por más bonito que sea, no pago 4800 € ni harto de vino (al menos mientras el aire siga siendo gratis).
Claro que si fuese multimillonario y no supiese qué hacer con el dinero, a lo mejor no me importaba tirarlo. Sólo a lo mejor ...
samtrom30
Mensaje  Noncondition Miér 1 Mayo 2013 - 17:33
Shocked
Comentando sobre la audición de Werner, que ha dado para un hilo larguísmo, si bien como es lógico en muchos momentos más ligero y divagador. Decía el compañero que no se hablaba de otras audiciones, y digo yo que si no se hace, será por que la asistencia no ha considerado que debiera hablar de ella por las razones que fuera.
Respecto a lo segundo, me refiero que el mercado en España, ya de por sí de dimensiones mucho más pequeñas que en países de nuestro entorno, ahora está liquidado como consecuencia de la crisis económica. No es que no haya más cera que la que arde, es que no hay cera para arder.
Abrazo.
Mensaje  gizmo Miér 1 Mayo 2013 - 17:45
Por qué no lo pondrán en el chasis del tamaño de un Trigon Vanguard??? entendería que no lo hicieran si todos sus productos utilizasen el mismo chasis por lo que diseñar y producir uno nuevo para el aparato en cuestión puede encarecer el producto ......pero no.
No obstante si valiese 600€ se vendería mucho menos......por no responder al perfil del consumidor "hi-end" wallbash
Cantidad de envíos : 5436
Mensaje  Mordecai Miér 1 Mayo 2013 - 17:51
Pues supongo que será algo tan sencillo como una cuestión de armonía estética con el resto de sus componentes.
Mensaje  samtrom30 Miér 1 Mayo 2013 - 18:01
gizmo escribió:No obstante si valiese 600€ se vendería mucho menos......por no responder al perfil del consumidor "hi-end"
En mi opinión, no es sólo que muchos aficionados asocien alto precio a alta calidad y a "exclusividad", es decir, que piensen que si un producto no es super caro no es bueno ni elitista.
Es que el fabricante debe pensar que, si el diseño y la fabricación del componente en cuestión no cuesta ni un 10% de lo que pide por él, pero hay aficionados con bolsillos holgados dispuestos a pagar MUCHO MÁS, no va a ser tan tonto de no aprovecharse.
Última edición por samtrom30 el Miér 1 Mayo 2013 - 18:07, editado 1 vez
samtrom30
Mensaje  papaito Miér 1 Mayo 2013 - 18:06
Very Happy Ni a mí, vistas estas barbaridades uno pasa olimpicamente. Quizá una de las preguntas seria a cuanto se paga cada una de las letras de dcs porqué no parece que por componentes y carroceria (por otra parte nada del otro mundo y muy lejos de los mecanizados de "otros") este aparatito pueda llegar a los casi 5000 euretes. Y quien más quien menos sabe lo que cuesta instalar un reloj de precisión en cualquier lector aunque no se llame dcs y vaya en una caja llena de aire.
¿Vale lo que cuesta?. La historia de siempre cool2
