Opera Consonance Reference 5.5
+11
Gul
Miguel Ronda
musicalfidelity
Mclolo
Azazel
Eduardo Martín Soto
15 participantes
Página 3 de 7.
Página 3 de 7. • 1, 2, 3, 4, 5, 6, 7
Re: Opera Consonance Reference 5.5
Esto es lo que ha contestado el vendedor
"Hello Luis,
the amplifier worked perfectly!
Please look at my reviews. 100% positive.
As you have seen, the amp has been packed safely and very elaborately by me. Better that is not possible without original packaging!
After your request to deliver the amplifier, I have told you that I do not take the risk of transport but you carry the risk!
If something is broken now, it must have happened during transport, even if I can not understand it. You have read my description. I have not offered shipping but pickup.
Do you think I will pick up an amplifier if there is a defect? For me, the amplifier was absolutely fine.
When the input switch turns freely, check to see if anything has come loose. Actually, the knob should have raster positions and not turn completely free? I rather suspect the defect in a small fuse.
The fuse can be found under the power plug input. There is a small shaft that you can pull out to the front. That's easy to swap. That's a cent article. It can happen, of course, with vibration of a transport tearing a fine safety thread.
Best regards, Volker.
Y éste es el vídeo que le he mandado.
https://youtu.be/NOfXSzbHuiw
"Hello Luis,
No me atrevo a abrirlo, no soy precisamente un manitas y no sabría cómo hacerlo.
¿Alguien conoce algún sitio en Madrid donde le puedan echar un vistazo?
¿Conocéis éste?.
http://sonitube.es/reparaciones-de-equipos-de-sonido/?gclid=CjwKCAiAhp_jBRAxEiwAXbniXcoSQxcTSnCjGAiGLldWUm-Y99hMalTfBYM0eqVg4MxMROCsQODtNBoCxQcQAvD_BwE
O éste
http://www.surmusicstudio.com/servicio-tecnico-amplificacion-sonido-hifi/
¿Conocéis éste?.
O éste
Sé que es de los mejores pero está en Huesca y no quiero enviar el aparato por agencia para evitar daños y gastos de envío. Después de esta lamentable experiencia prefiero llevarlo y traerlo en mi coche. Estoy seguro que en Madrid también debe haber profesionales capacitados. Os pido consejo
Lo que te comenta es muy lógico.
Abrirlo es facil, yo llamaría a algún amigo manitas de la electronica y revisaría eso mismo. Son 10 minutos y apenas hay riesgo.
Suerte y saludos!
Suerte y saludos!
Miguel Ronda- Cantidad de envíos : 57
Fecha de inscripción : 22/01/2012
Mis amigos entienden más de carburadores que de válvulas, jajajaja
Solo he visto 1 tornillo en cada uno de los dos laterales y 2 en cada uno de los 4 lados situados en la base de debajo (los puedo tocar con los dedos), aparte de los de las válvulas de la foto
Quitando el tornillo allen puedo quitar fácilmente el botón del volumen pero soy incapaz de hacer lo mismo con el selector de fuente sin miedo a romperlo.
El botón del selector de fuente soy incapaz de quitalo y eso que he tirado fuerte, incluso con el tornillo Allen completamente sacado.
El de volumen, como ves en la foto, ha sido muy fácil.
quesvi escribió:Luiluilui escribió:El botón del selector de fuente soy incapaz de quitalo y eso que he tirado fuerte, incluso con el tornillo Allen completamente sacado.
Eso no lo toques . Tienes que abrir sin quitar eso
http://www.opera-online.de/technik/innen_ref55.html
Aquí dentro
Lo siento no entiendo.
Que tengo que quitar exactamente
Pues hay tienes la prueba, el selector destrozado será una reparación barata.
Intenta hacer un puente para poder seleccionar una entrada y seguro que tendrás power de salida.
Localización : Barna
Creo que es igual que éste que te enlazo, https://www.electronicaembajadores.com/es/Productos/Detalle/IT5A043/interruptores-conmutadores-pulsadores/conmutadores-rotativos/conmutador-rotativo-4-posiciones-3-circuitos, son 3'25€, IVA incluido.
¡Suerte y que lo disfrutes pronto y por mucho tiempo!
Javier
Javier
Gul- Cantidad de envíos : 569
Está chupao repararlo. Solo hay que comprar el conmutador, cortar el vástago a medida,que es de plástico, y soldar uno a uno los hilos en el nuevo conmutador.
Edad : 65
El conmutador que ha puesto Gul es el correcto.
Para que se suelte tiene que haber recibido un golpe, seguramente un golpe frontal en el mando del selector.
Edad : 65
He comprado el selector y estaño pero no sé si llevarlo a Sonitube que lo tengo a 2,4 kms para que me lo arreglen y hagan una revisión general del aparato. No creo que me cobren mucho y me quedo más tranquilo.
Muchísimas gracias a todos.
» DYLAN EUROPA 2015 y.... lo que venga.....DESERT TRIP 2016.....NOBEL DE LITERATURA....... Still On The Road
» Altavoces para música clásica y ópera
» Audicionar cajas Opera Audio M-15
» Altavoces Opera
» DVD de ópera
» Altavoces Opera
» DVD de ópera
Página 3 de 7.
