AudioQuest Hard RCA Splitter
Hola compañeros,
A ver si me podéis echar un cable (nunca mejor dicho)...
Tengo un Dac estacionario con una única salida RCA y me gustaría conectarle el ampli integrado y un amplificador de auriculares.
Este tipo de splitter funciona bien o degrada la señal? Existe algún splitter de mayor calidad 100% fiable?
https://www.audioquest.com/accessories/splitters-connectors-adaptors/adaptors/hard-rca-splitter-male-to-2-female
Si funciona bien me iría de lujo ya que ando detrás de la compra de un ampli de auriculares puro y hasta ahora debido a la única salida RCA que tiene mi Dac me veía en la tesitura de tener que comprar un Dac/Ampli de auriculares que es bastante más caro y cuesta más acertar con su perfil sonoro.
Saludos y gracias
Saludos y gracias
pororom- Cantidad de envíos : 134
Fecha de inscripción : 20/12/2010
Re: AudioQuest Hard RCA Splitter
https://www.head-fi.org/threads/best-type-of-rca-splitter-to-use.596369/
"Provided that both input impedances are sufficiently high and more or less equal if you split a signal into two there will be no loss of signal quality but the strength will be halved. Resulting in a 3dB loss. So if you keep on doing it eventually it's going to effect your S/N ratio. The convention is you can safely split up to 3 times provided you have sufficient gain available. Which you probably have. Extra cable length may also lead to noise if you have a ground issue.
Unbalanced line level splitters (and combiners) are rare. You can see the problem. Connecting together the grounds on several consumer grade appliances spread over a wide area is almost certain to lead to ground loop issues. That is why professionals use something called a distribution amplifier for this task. It not only splits (or combines) a signal it also converts unbalanced to balanced and provide a small amp per channel to adjust the gain. You can get cheap ones from the likes of Berhinger and ART or top of the range from Drawmer and Radial.
http://www.behringer.com/EN/Products/MX882.aspx
http://www.drawmer.com/products/signal-distribution/da6.php
I still think that if the OP has the cash he would do best with a basic audio interface which is designed for the task in hand. And many other useful functions. You can get a 2 in 2 out unit with headphone from around $150. better would be 2 in and 4 out which starts at ~$200. If that's too steep then stick with a simple Y lead for now and hope you don't get a ground loop."
Es cuestión de probar pero tienes splitters idénticos al Audioquest por 1/4 de ese precio.
El que comentan en Head-fi es este
https://www.amazon.es/Behringer-MX882-mezclador-Mezclador-inoxidable/dp/B0002E57D4/ref=sr_1_1?ie=UTF8&qid=1532503842&sr=8-1&keywords=mx882
Yo personalmente buscaría un artilugio sencillo que tenga un conmutador para elegir una u otra salida. Incluso lo podrías hacer tú y seguramente sea de mejor calidad. Simplemente por en google "Diy rca audio splitter"
O si no quieres hacerlo tú y no tienes mucha prisa
https://es.aliexpress.com/item/2017-Lastest-Douk-Audio-Passive-Stereo-4-IN-1-OUT-RCA-Audio-Splitter-Switcher-Selector-DIY/32785478572.html
Hola leeré con atención lo que dicen en Head Fi.
Los que me indicas son demasiado grandes, busca solucionarlo con un aparatejo lo más pequeño posible...
pororom escribió:Hola leeré con atención lo que dicen en Head Fi.
La base de funcionamiento cabe en una caja de cerillas
Que ampli integrado tienes, ya que a lo mejor puedes cconectar el ampli de auris a este y te evitas todo el lio.
De no poder ser, lo mas barato es probar con " Adaptador RCA macho a 2 RCA hembra " en cualquier buscador y por menos de 3 EUR ya lo tienes.
David
David
Radeon- Cantidad de envíos : 180
Fecha de inscripción : 11/01/2013
Tengo un Rega Elicit-R y en el manual pone esto...por lo que parece se puede conectar directamente un amplificador de auriculares...
Record Output Link - This output is in parallel to the Record output, and can be used to drive ancillary components like headphone amplifiers etc, when a signal unaffected by the volume control and selected by the main input selector is required.
Lo que no entiendo es como se tiene que seleccionar esa salida desde el Elicit (una vez conectado el amplificador de auriculares a la salida que indican) y como se controla el volumen del amplificador de auriculares una vez seleccionada.
Delante tiene estos botones:
Mute
Direct
Record
Manual del Rega Elicit-R
http://www.rega.co.uk/uploads/rega-elicit-r-english-manual-mk2-april-2014.pdf
No sé si desde el mando a distancia se puede hacer...
Remote Solaris
http://www.rega.co.uk/solaris-remote.html
Manual
http://www.rega.co.uk/uploads/regaremotedata.pdf
os pongo imagenes de la parte trasera y delantera
Mute
Direct
Record
Remote Solaris
Manual
Hola de nuevo,
Creo que tienes suerte con tu ampli.
Segun veo hay tres posibles maneras de conectar un ampli de auris: a la salida Record Output; a la salida Record Output Link y a una salida Pre-Amp Output.
Se tiene que probar cual va mejor, segun entiendo la Record Output es la tipica salida apara acceder a un sistema de copia, no depende del volumen del ampli y solo copia a la fuente seleccionada para oir ( para usar esta debes selecionar el input donde conectes el Dac con el volumen al minimo y ya esta); La Record Output Link es mas o menos lo mismo por no decir lo mismo; la salida Pre-Amp Output es en teoria para conectar otra etapa de potencia o si quisieras un subwoofer o tambien podrias colocar aqui tu ampli de auris, ya que no depende del volumen y esta en paralelo con el selector de input.
Como ves parece facil, en lo referente al volumen del auricular, no te preocupes, tu amplificador no afecta a estos ya que todos los amplis de auris llevan su propio mando de volumen.
Si necesitas alguna aclaracion, no seas timido que todos hemos empezado de la nada.
Bueno todo esto es en mi opinion.
Hola Radeon, ok si te entiendo bien, dejo la conexión del Dac al Elicit tal como la tengo (imput 4), conecto el ampli de auriculares a la salida Record Output Link (es la que recomiendan en el manual) y cuando quiera escuchar desde el ampli de auriculares me limito a encender el Elicit y el ampli de auriculares y escucho desde el ampli de auriculares sin más (manteniendo el pote del Elicit a 0). Supongo que la señal en este caso pasa por dentro de los circuitos del Elicit y la recoge el ampli de auriculares al estar encendido. Luego cuando quiera escuchar directamente a las cajas con tener apagado el ampli de auriculares supongo que es suficiente sin tener que desconectarlo del Elicit.
Es así?
Saludos y gracias
Es así?
Saludos y gracias
Otra duda...
Tengo que presionar el botón mute delantero cuando quiera escuchar por el ampli de auriculares?
Ok
Lo has entendido perfectamente.
La idea de usar el mute se tiene que probar, probablemente es mejor que la de asegurarse de bajar el volumen, disculpa ya que mi previo no tienen mute y nunca pienso en ello.
David
Ok
David
Ok, ahora toca buscar un buen amplificador de auriculares que no sea muy caro...
Saludos y gracias
Saludos y gracias
En la seccion compra venta tienes un project a 50€, no se cual es ni tengo referencias, pero por ese precio no creo compres nada nuevo, además lo venden en Barcelona y por tanto supongo lo puedes ver antes de comprar.
Saludos y suerte en la búsqueda,
David
Yo uso 2 un Rhinelander de Lehmann y un HA 200 de Nuforce.
David
» Consulta sobre cables Audioquest de interconexión analógica (respuesta de Audioquest)
» audioquest forest+audioquest argent
» Audioquest Coffee Usb o Audioquest Carbon Usb
» USB A splitter o Coaxial?
» ¿Conector Splitter digital?
