Ipod tube output stage
A.P.P.
Me he comprado un aparatito para el Ipod que consiste en una salida de válvulas como la que llevan algunos lectores de CD.
El caso es que yo de válvulas ni idea y quería que alguien me comentara qué tipo de válvulas son las que lleva: Philips 6DJ8s, y si son mejorables. De ser así, ¿por cuáles?
Gracias a todos.
MUSICAL FIDELITY X-10D
Gracias a todos.
Última edición por Kapton el Mar Mar 16 2010, 12:29, editado 2 veces
Re: Ipod tube output stage
Leo en una página sobre válvulas lo siguiente;
6DJ8:
This is the standard incarnation of this tube. It was made both in the USA and in Western Europe. GE and Sylvania both made USA versions, and are fairly good quality. The GE tubes have an RF shield sprayed on inside the glass, making the inside look dark. This is NOT an indication of a burned out or used tube. RCA tubes were often made by either Mullard or Amperex in Britain or Holland. The most popular NOS vintage tubes are those made by Telefunken, Amperex, Siemens or Mullard, and are usually also labelled ECC88. See the next paragraph for this description.
ECC88:
This is the European designation for the 6DJ8 type tube. It is the same tube as a 6DJ8 and often the tube has both type numbers on it. The popular vintage tubes here are those by Telefunken, Amperex, or Mullard. The Telefunken are said to sound the best, and are the most difficult to find of all of these brands. All Telefunken tubes have a tiny diamond shape molded into the glass on the bottom, and have a very chalky ink on the surface which often is partially wiped off. Beware! These tubes are being reproduced in China, and look like the real thing, complete with diamond mark. The tipoff is the label: the fake labels will not wipe off.
The Amperex can be found with a white label and the treble clef logo (rare), the Bugle Boy cartoon tube logo, Amperex in white ink, and the orange world logo. The orange world logo is the newest, and can be found in both standard "L" bracket top getter, and the rarer (and said to sound better) "A" frame top getter. The A-frame looks like a little metal "A" holding up the getter element on the top of the tube internal structure. I have also seen the A frame getter on some Mullard and Genalex (G.E.C.) tubes. The Bugle Boy is the most popular, almost to being a "designer" label, which has driven the price up and supplies down. See note below about Bugle Boy 6DJ8 tubes. I believe any of the Amperex / Philips Holland 1960s and 1970s 6DJ8 tubes are excellent, no matter which one you use. The tubes made with the plain white label (Amperex, DuMont, Hewlett-Packard, Beckman and others but all labelled "Holland") were made in the same factory as the Bugle Boy tubes and sound the same, but are often bargain priced due to low demand. Beware! The Bugle Boy tubes are being reproduced today! The box of the new tubes is even an identical green-and-yellow like the original, but it says "Bugle Boy" on it, and some even show the cartoon tube on the box. Original Amperex tubes NEVER had the words "Bugle Boy", or the cartoon tube, on the box. The Bugle Boy moniker is a slang name that audiophiles coined for the the little cartoon tube on the tube's label. The new tubes have fooled even some seasoned audiophiles! These are junky Chinese made tubes with the old label. The company vending them says they have the original burn-in racks from the old Holland factory. Big deal!! The old burn-in racks are not going to help a crappy tube. Stick with the vintage tubes while you still can!
Mullard 6DJ8 tubes are excellent as well, but are more difficult to find. They often made 6DJ8 tubes for other labels, like RCA, Zenith, and other USA brands. They have several seams molded into the top of the tube.
6DJ8:
ECC88:
Pero luego también leo que la 6922 y la E88C/01 son mejoras de las anteriores...
Vamos, que estoy hecho un lío.
Help is needed!
Help is needed!
¿Pero de verdad te merece la pena?
Yo creo que esto ya es trastear por trastear. Quedate con las válvulas que trae, que al fin y al cabo solo es para el i-pod, coñe.
Lo que te faltaba ya.
A.P.P.- Cantidad de envíos : 760
Localización : El Bosque de los Pitufos
Pues yo creo que sí. Es un importante upgrade para mi Ipod.
No todo va a ser Wadia...
Por cierto que ayer estuve con mi padre y el hombre le puse algunos discos suyos míticos y se quedó impresionado con el equipo. Qué satisfacción ver a mi padre escuchando mi equipo... qué blandito soy...
Es verdad A.P.P. , este Kapton me tiene desconcertado. Me echa una bronca tremenda por comprar las wilson, que si cacharreo, que si tal ...y ahora él se enreda con el tema de las válvulas!!! Ojo, me parece perfecto, pero me descuadra totalmente...
UN abrazo y que lo disfrutes, ya me contarás como suena
Miguel
Miguel
romea- Cantidad de envíos : 323
Cachis en diez... ¡¡¡YO NO TE ECHÉ NINGUNA BRONCA!!!romea escribió:este Kapton me tiene desconcertado. Me echa una bronca tremenda por comprar las wilson...
Me parecen unas cajas deliciosas, simplemente te dije que para que "suenen" necesitan de mucho trabajo, mucha electrónica y mucho de todo y no todo el mundo se compromete tanto con unas cajas como nuestro amigo APP. Ahora bien, cuando por fin se consigue hacerlas sonar son DELICIOSAS... sin llegar al nivel de las Apogee, pos supuesto
romea escribió:Es verdad A.P.P. , este Kapton me tiene desconcertado. Me echa una bronca tremenda por comprar las wilson, que si cacharreo, que si tal ...y ahora él se enreda con el tema de las válvulas!!! Ojo, me parece perfecto, pero me descuadra totalmente...
Miguel
Jajajajajajajajajajajajajajajajajajaja.
Que más puedo decir. Has expresado mis pensamientos, mucho mejor de lo que yo lo habría hecho.
Sin duda estáis los dos ya en la secta Wilson.
Vaya panda.
Repelentísimos, sordos perdidos y siempre insatisfechos
Vaya panda.
Kapton escribió:Cachis en diez... ¡¡¡YO NO TE ECHÉ NINGUNA BRONCA!!!romea escribió:este Kapton me tiene desconcertado. Me echa una bronca tremenda por comprar las wilson...
Me parecen unas cajas deliciosas, simplemente te dije que para que "suenen" necesitan de mucho trabajo, mucha electrónica y mucho de todo y no todo el mundo se compromete tanto con unas cajas como nuestro amigo APP. Ahora bien, cuando por fin se consigue hacerlas sonar son DELICIOSAS...sin llegar al nivel de las Apogee, pos supuesto
De nuevo más jajajajajajajajajajajajajaja.
Con respecto a lo puesto en negrita, eso no te lo crees ni tu .
Las Aposs son más fáciles de ubicar y no requieren de tanto trabajo acústico para sonar decentemente, aunque si de una electrónica con un par de..........
Pero tengamoslo claro, las Wilson amarfilan mucho más
¡¡¡¡¡PERO BUENO!!!!! Si eso lo he murmurado tan bajito que apenas se ha oido... Como usuario de Wilson pensé que ni te ibas a percatarA.P.P. escribió:
Te falta mucha literatura sobre la Jijend para entender qué es la brutalidad....
Muchas IRS, muchas WAMM, muchas ESL, muchas ¿?¿?¿? pero al final del camino la única que está es... UNA APOGEE.
Ya sé que no me echaste ninguna bronca, pero era para picarte un poco. UN abrazote
Miguel
Hola Kapton,
¿cual es concretamente ese aparatito con válvula que has comprado para el Ipod?
Salu2
Elvis
Salu2
Elvis
elvis- Cantidad de envíos : 412
Localización : Somewhere over the rainbow
El aparatito lo definen como un buffer de salida de válvulas.
Última edición por Kapton el Mar Mar 16 2010, 12:27, editado 1 vez
Yo tengo el Arcam IrDock con mi Touch. ¿has notado el toque de la válvula al poner dicho aparato?
Perdón por el
Salu2
Elvis
Perdón por el
Salu2
Elvis
Hoy he estado probando y he sacado algunas conclusiones interesantes....
Cuenta, cuenta........
Salu2
Elvis
Salu2
Elvis
No he puesto cables Cello Strings 1 que es lo que uso en el equipo principal, simplemente han sido unos Van Den Hul de gama media/alta que tengo por casa.
Diferencias existen, el tema es si verdaderamente son útiles o no.
En mi caso los pros:
Más suavidad en la difícil parte de medio/agudo
Mayor eufonía, se nota que la música adquiere cierto color
Coherencia escénica
Los contras:
Pérdida de algo de dinámica
Sonido más plano
Pérdida de parte del medio/grave
Globalmente:
Lo utilizo para el Ipod nada más, es decir, música en formato MP3. Lo uso para música de fondo mientras comemos o para leer o para... y considero que la música se convierte en algo más relajada y retrasada con lo que imho merece la pena.
Pero es un cacharro peculiar, puede gustar pero entiendo que en un momento dado si lo utilizamos en una fuente digital de cierta calidad, yo no lo he conectado al Wadia -por ejemplo-, intuyo que habrá pérdida de calidad. Mi opinión es que hay que "saber" antes de comprarlo qué fuente digital tenemos en cuanto a calidad sónica y si verdaderamente no es buena este aparato puede mejorarla.
Aparato curioso cuando menos.
Funciona mejor cuando lleva ya encendido al menos 45 minutos.
Coherencia escénica
Los contras:
Sonido más plano
Globalmente:
Aquí tenemos unas fotografías del cacharro de marras por dentro, la construcción es estupenda:
Muchas gracias Kapton por tus excelentes apreciaciones. Por lo que comentas el sonido en general es bueno pero con las características propias de un sistema a válvulas que por lo general dan calidez y y suavidad a consta muchas veces de perder cierta dinámica y análisis.
Es otra forma de escuchar la música que puede gustarte o no. A mi personalmente me encanta el sonido de la válvula.
A mi me pasa un poco como a tí, utilizo el Ipod para poner música de fondo cuando juego con los peques o estoy de aqui para alla haciendo cosas en casa, con lo que no le concedo demasiada importancia pero como buen cacharrofilo siempre te gusta tener las cosas medianamente decentes .
Gracias de nuevo, un aparatillo para tener en cuenta.
salu2
Elvis
salu2
Elvis
Kapton escribió:Me he comprado un aparatito para el Ipod que consiste en una salida de válvulas como la que llevan algunos lectores de CD.
Gracias a todos.
Hola Kapton,
en Peebles hemos rediseñado la red de realimentación del X-10D para que el aparato tenga aprox 25dB de ganancia, con lo que además de las ventajas que supone la menor impedancia de salida del buffer, el nivel del sonido de iPod se aproxima más al estándar del resto de fuentes de audio.
Escribenos si te interesa saber más.
Saludos, Luis.
http://peebles-engineering.com
» output preamp, output tape.
» ¿SE PUEDE CONFIGURAR UN TUBE BUFFER EN MODO BALANCEADO A PARTIR DE 2 TUBE BUFFERS ESTEREO?
» ¿Algo parecido a un iPod pero mejor que un iPod?
» USBRIDGE, AUDIOPHILE USB AUDIO OUTPUT
» Moving Coil Low Output Cartridges
