PROMOCION DACs NORTHSTAR POR APERTURA BROKER AUDIO SHOP
Hola buenas tardes,
Con motivo de la apertura de Broker Audio Shop y solo hasta el próximo 30 de Octubre , consigue un precio nunca realizado (30% DTO. ) en las electrónicas DAC de North Star Design , marca Italiana y una de las lideres de venta en el mercado Asiatico con todo lo que puedes pedir en un DAC : Chip Ess Sabre , native DSD, Toroidales separados entre sección analógica y digital, USB asíncrono,etc (más abajo tienes las especificaciones técnicas ).
NO PIERDAS ESTA OPORTUNIDAD ¡!!
NORTH STAR EXCELSIO 32-384 DSD NORTH STAR IMPULSO 32-384 DSD
PVP 2.675 € AHORA 1.873 € PVP 1.775 € AHORA 1.155 €
NORTH STAR INTENSO 32/384 DSD NORTH STAR SUPREMO 32-384 DSD
PVP 1.225 € AHORA 858 € PVP 3.950 € AHORA 2,765 €
Technical Specifications
Asynchronous USB Hi-Speed Audio 2.0 compliant ( all units)
Native DSD 2.8 - 5.6 MbiVs and 384 kHz - 32 bit on USB ( all units)
DPLL ON-DAC for maximum jitter reduction ( all units )
Separated low noise power supply for USB port ( Excelsio/Supremo)
Digital filter selectable from setup for PCM and DSD reproduction ( all units )
Separated low noise power supply for USB port ( all units )
Coaxial digital input coupled with pulse transformer (all units)
AES/EBU digital input (Excelsio/Supremo )
Discreta components analogue stage with very low noise matched transistors (Supremo)
Organic polymer capacitors on analogue stage ( Supremo )
High precision film resistors and capacitors on analogue stage (Excelsio/Supremo)
Separata analogue ground plane for each channel section with star connection (Excelsio/Supremo)
lntegrated components analogue stage with flagship OPA 1611 (Excelsio/Supremo)
lntegrated components analogue stage with low noise LME49870 (Excelsio)
WBT Nextgen™ flagship RCA connectors ( Supremo)
Neutrik® gold plated XLR connectors (Supremo)
OFC cable hook-up ( Supremo )
Driver not necessary on Apple OSx and Linux ( all units )
ASIO driver for DSD reproduction on Windows OS ( all units )
DAC ESS Sabre flagship ES9018 or ES9016 in double balanced configuration ( depend unit )
Advanced 12S port supports PCM until 384-32 and native DSD (all units )
Seperated toroidal transformers for analog and digital sections ( Excelsio/Supremo)
Balanced and unbalanced analogue outputs ( all units )
Cualquier duda , estoy a tu disposicion .
Jose
Broker Audio Shop Valencia
Tfno . 961 071 936
Jose
Tfno . 961 071 936
Última edición por BAS VCN el Vie 16 Oct 2015 - 15:47, editado 1 vez
BAS VCN- Cantidad de envíos : 86
Fecha de inscripción : 06/09/2015
Re: PROMOCION DACs NORTHSTAR POR APERTURA BROKER AUDIO SHOP
Buenas noches, solamente indicar que en esta promoción también esta incluido el modelo INCANTO, quienes deseen escucharlo solo deben pasar por nuestras instalaciones de Valencia.
Un saludo .
Buenas tardes ,
Una aclaración obvia , se tratan de una oferta de producto NUEVO o NUEVO de EXPOSICION.
Gracias. Un cordial saludo.
Jose
Broker Audio Shop
Jose
Broker Audio Shop
Última edición por BAS VCN el Vie 16 Oct 2015 - 15:48, editado 1 vez
Hola buenas tardes ,
Saludos cordiales,
Jose
961 071 936
Broker Audio Shop
Saludos cordiales,
Jose
961 071 936
Broker Audio Shop
» Apertura de nueva local Broker Audio Shop & Club en Valencia.
» Broker Audio Shop
» EL INTERIOR DE BROKER AUDIO SHOP
» ATM by JESUS ALEJOS en BROKER AUDIO SHOP
» STIRLING BROADCAST EN BROKER AUDIO SHOP
» Broker Audio Shop
