Análisis del cable ethernet Audioquest Vodka ($340) en ArsTechnica
Análisis del cable ethernet Audioquest Vodka ($340) en ArsTechnica Empty Análisis del cable ethernet Audioquest Vodka ($340) en ArsTechnica
Mensaje  pablopi Sáb 8 Ago 2015 - 8:31
http://arstechnica.com/gadgets/2015/07/ars-prepares-to-put-audiophile-ethernet-cables-to-the-test-in-las-vegas/
http://arstechnica.com/gadgets/2015/07/even-vegas-strangers-agree-340-audiophile-cables-make-no-difference/
Lo mejor de todo, el cable se enorgullece de ser de categoría 7 (a pesar de que no existe un estándar TIA), no obstante no pasa de categoría 6A (y eso por los pelos), en el banco de pruebas:
http://arstechnica.com/gadgets/2015/07/340-audiophile-ethernet-cable-gets-a-marginal-pass-on-the-test-bench/
"While the cable did pass 6A patch cord standards it did so within the tester's margin of error—meaning that if it were run on a variety of well-calibrated testers it might sometimes fail," explained Denke in his analysis. "The difficulty, as is typical for Cat 6A, was near-end crosstalk."
This means that for all the Vodka’s sturdy construction and heft, it exhibited near-end crosstalk numbers that were borderline relative to the spec—at worst, only 0.6dB above the spec’s crosstalk limit (see What Does This Report Mean? on the Blue Jeans Cable site for a more detailed explanation of the results). By way of comparison, Denke also included a test for an off-the-rack Blue Jeans Cable Cat6a patch cable of the same 1.5m length, which demonstrated a worst case headroom of 1.5dB.
Última edición por pablopi el Sáb 8 Ago 2015 - 13:48, editado 2 veces
Cantidad de envíos : 5817
Localización : Castellón
http://pablofelip.online
Análisis del cable ethernet Audioquest Vodka ($340) en ArsTechnica Empty Re: Análisis del cable ethernet Audioquest Vodka ($340) en ArsTechnica
Mensaje  Jaime Sáb 8 Ago 2015 - 9:04
Pues imagínate lo que pasara con un cable de 2€.
Jaime
Jaime
Cantidad de envíos : 1156
Localización : Las Palmas
Mensaje  pablopi Sáb 8 Ago 2015 - 9:25
Jaime escribió:Pues imagínate lo que pasara con un cable de 2€.
Muchos cables chinos de 2€ llegan solo a cat5e, aunque eso no suele suponer problema alguno para hacer backups de gigabytes a velocidades gigabit sin alterar ni un solo bit en destino.
En cualquier caso se pueden conseguir cables de cat6 o 6a por unos pocos euros, no hace falta gastarse casi 300€ para conseguir un cable que cumple esa especificación por los pelos.
Mensaje  mvdventura Sáb 8 Ago 2015 - 10:35
Ay, los cables, los cables...
Creer o no creer...
La ciencia o la religión...
Ahora, la "visión" de un "religioso profesional":
"Lee Hutchinson [Ars Technica] also repeatedly quotes me as saying the differences I heard between various Ethernet cables were "not subtle or slight" and "as plain as day." This, according to Lee, was "The claim being examined..." in Vegas. I'm honored. The problem is, I was clearly saying these "not subtle or slight" and "as plain as day" differences were heard in my system. If I listened through the Ars test setup, Grado RS2e headphones connected to a Dell M2800 laptop, my guess is I'd be hard-pressed to hear the difference between an MP3 and an M16. Details, details. Let the show go on."
Al final la culpa la tiene el equipo...
Cantidad de envíos : 1778
Mensaje  Migeru Sáb 8 Ago 2015 - 13:11
Si regalan una botella de vodka con el cable ya sabéis donde están las diferencias
Devil
Este mundillo tiene a veces unas cosas tan disparatadas que no cabe más que reir, pero empiezo a estar harto de que una funda de cable justifique el número de ceros
Que hartura " ....Gen Santa"
Migeru
Migeru
Cantidad de envíos : 871
Edad : 62
Localización : Islas Baleares
Mensaje  pablopi Sáb 8 Ago 2015 - 15:17
Como siempre What a Face
