Snake-Oil Alert: Denon Sells ‘Audiophile’ Ethernet Cable for $500
Denon is hawking an ethernet cable for an astonishing $500. How can the company possibly justify this quite ludicrous markup on what is essentially a tube for shifting ones and noughts across the network? As you might have guessed, it’s because the “ultra premium Denon Link cable was designed for the audio enthusiast“. [Emphasis added]
This, we presume, is the same audio enthusiast who might buy Monster speaker cables or similarly “danceable” wires. Denon mitigates this nonsense by using decent materials inside — “high purity copper wire” for instance — but this is a cable for digital signals, people. Sure, a badly made Cat 5 will pick up interference, but it would have to be made from steel wool and gaffer tape to cause a problem in a 1.5 meter (59″) length, which is the size of the AK-DL1.
One final insult to your intelligence: The cables have arrows on them to “indicate correct direction for connecting cable”. Perhaps so the pampered electrons don’t get lost on their way.
Si alguien necesita traducción que lo diga ....
Re: Snake-Oil Alert: Denon Sells ‘Audiophile’ Ethernet Cable for $500
Y si os quereis reventar de risa, podéis leer algunas de las reviews en Amazon:
REVIEWS
REVIEWS
Bueno, tampoco es tan caro. Tiene flechita para saber en que sentido van los datos. Lo malo de esto es que hace falta otro cable, ya que como todos sabemos en este tipo de conexión los datos son bidireccionales,
Uff que torpe. La flecha es bidireccional. Ya no me gusta.
Ahora lo puedes comprar nuevo por 9.999,00 $ y solo 4,99 $ de shipping, una ganga!!!!!.
http://www.amazon.com/gp/offer-listing/B000I1X6PM/ref=sr_1_1_olp?ie=UTF8&qid=1297624630&sr=8-1&condition=new
Yo creo que eso no puede ser, que hay algún error.
antonioguerto- Cantidad de envíos : 326
Localización : Cádiz
Fecha de inscripción : 28/01/2011
antonioguerto escribió:Ahora lo puedes comprar nuevo por 9.999,00 $ y solo 4,99 $ de shipping, una ganga!!!!!.
Jajaja....
Los tipos que supuestamente "venden" los cables a esos precios (9.999$, 999$ y burradas así) son unos cachondos que ponen unos comentarios en la venta que no tienen desperdicio.... muy en consonancia con la idea inicial de Denon de venderlos a 500$...
» Audioquest cable USB, modelo coffee: impresiones (snake oil?)
» ¿WI-FI o cable Ethernet?
» Cable Ethernet
» ¿Se nota un cable ethernet de calidad?
» Cable ethernet para LUMIN D2
» Cable Ethernet
