Nuevos Yamaha NS-3000
+8
Izan
kerouack
antoniopax
tente
odisea
12 participantes
Nuevos Yamaha NS-3000 Empty Nuevos Yamaha NS-3000
Mensaje  poolside Miér 8 Abr 2020 - 13:15
Specifications Yamaha NS-3000
   Type: three-way passive (library) speaker (error en la nota oficial, es dos vías)
   16 cm boomer
   3 cm tweeter
   Zylon membranes
   Frequency response: 39 Hz -60 kHz (+ -10 dB)
   Rated power: 60 W
   Max power: 120 W
   Sensitivity: 87 dB (2.83V at 1m)
   Cutoff frequency: 2.8 kHz
   Impedance 6 ohms (minimum 4.6 ohms)
   Dimensions: 306 x 629 x 401 mm
   Weight: 13.1 kg
Connoisseurs of the very high-end speaker NS-5000 (again this 5000 series) will not be disoriented. Indeed, the NS-3000 does not only share its prefix, it is also its little sister a little smaller and simpler.
Moving from a three-way topology to a two-way topology, the NS-3000 incorporates a 16 cm boomer dedicated to bass and midrange, and a 3 cm tweeter for treble. Both use a Zylon membrane, a polymer that Yamaha claims is as swift as the beryllium used by Focal. The filter, simpler than that of the NS-5000 but still imagined by Yamaha, uses components from Mundorf.
The formwork seems (to be specified) in plywood, possibly based on Hokkaido birch, with an internal suppression system and an acoustic absorber specially developed for this enclosure.
Even if its dimensions (306 x 629 x 401 mm) and its weight (13.1 kg) make it a bookshelf speaker, the NS-3000 is especially intended to rest on its dedicated base in metal, delivered as standard.
The Yamaha NS-3000 scheduled for release in July, but no price has yet been communicated.
Nuevos Yamaha NS-3000 Gal_Yamaha_NS3000_1
Nuevos Yamaha NS-3000 Gal_Yamaha_NS3000_13
Nuevos Yamaha NS-3000 Gal_Yamaha_NS3000_2
Nuevos Yamaha NS-3000 Gal_Yamaha_NS3000_3
No sé si hay un error en las dimensiones, porque no veo los 62'9 cm por ningún sitio, aunque parecen bastante profundos, pero no tanto scratch
Cantidad de envíos : 3748
Localización : Wisconsin
Nuevos Yamaha NS-3000 Empty Re: Nuevos Yamaha NS-3000
Mensaje  odisea Miér 8 Abr 2020 - 19:46
Efectivamente, hay un error, son:
Dimensions ébénisterie (L x P x H, mm) : 244 x 326 x 394
odisea
odisea
Cantidad de envíos : 824
Localización : Rubi
Mensaje  poolside Miér 8 Abr 2020 - 19:54
Eso ya cuadra más
Mensaje  tente Jue 9 Abr 2020 - 11:40
Sobre el precio, se sabe algo?.
Yamaha debería hacer algún tocadiscos en la línea de las nuevas series 1200 en adelante: sin llegar al 5000 y por encima de los actuales.
tente
tente
Cantidad de envíos : 1565
Mensaje  poolside Jue 9 Abr 2020 - 11:45
"The Yamaha NS-3000 scheduled for release in July, but no price has yet been communicated." Very Happy
Mensaje  tente Jue 9 Abr 2020 - 11:58
poolside escribió:"The Yamaha NS-3000 scheduled for release in July, but no price has yet been communicated." Very Happy
Lo leí, pero hay veces que las webs/tiendas pueden hacer pronósticos sobre precios orientativos, aunque me puedo imaginar por donde irán los tiros.
tente
tente
Mensaje  poolside Jue 9 Abr 2020 - 12:01
Dí una cifra Wink
Yo ni idea, la verdad, cualquier cifra que pienso me parece sinsentido Embarassed
Mensaje  tente Jue 9 Abr 2020 - 12:10
poolside escribió:Dí una cifra Wink
Pues....si las ns5000 rondan los 15000€ y las ns3000 son mucho más pequeñas, echaremos unos 3000€ por eso de igualar cifras y múltiplos Very Happy
tente
tente
Mensaje  poolside Jue 9 Abr 2020 - 12:23
Cuidao que las NS-5000 están ahora a 11.999 en Studio22, no es poca rebaja....
Mensaje  tente Jue 9 Abr 2020 - 12:26
poolside escribió:Cuidao que las NS-5000 están ahora a 11.999 en Studio22, no es poca rebaja....
Siguen siendo 2 kilazos de las antiguas pesetas. Las ns3000 le quitamos la parte proporcional respecto a las ns5000, 15-20%.
Como está la situación, no queda otra que esperar para los PVP.
tente
tente
Mensaje  poolside Jue 9 Abr 2020 - 12:39
Ná, que son dos kilos, a lo grande, las NS-3000 son muy pequeñas
Mensaje  MERIDIAN Jue 9 Abr 2020 - 15:32
En la web de supersonido, esta ya anunciado.
En las características técnicas en la web pone.:
PVP recomendado:
4.799 €
IVA incluido
Cantidad de envíos : 2988
Mensaje  poolside Jue 9 Abr 2020 - 18:32
MERIDIAN escribió:En la web de supersonido, esta ya anunciado.
PVP recomendado:
4.799 €
IVA incluido
No los veo ¿tienes el link?
Mensaje  antoniopax Jue 9 Abr 2020 - 19:13
pues totalmente inentendible pagar 4000 euros por unas minicajas yamaha ns-3000 lo flipo de veras, si por 1500 con suerte te encuentras con unas yamaha ns-1000m como las que yo tengo.
que a mi me costaron ese dinero y lo de las ns-5000, si hombre si gastate 2 kilos de las antiguas ptas otro sinsentido, que hay gente que lo paga ole por ellos.
y no no es envidia de no tenerlas y el que tiene esa pasta las tenga, yo con las mias mis yamaha ns-1000m mas feliz que una perdiz.
Nuevos Yamaha NS-3000 F551ea0a6f741a1251d88bbcf79e5e88o
Última edición por antoniopax el Jue 9 Abr 2020 - 21:40, editado 1 vez
antoniopax
antoniopax
Cantidad de envíos : 1531
Mensaje  odisea Jue 9 Abr 2020 - 20:00
Di que si Antonio, que con nuestras NS-1000 vamos al fin del mundo y por pocas perras... Aplause Aplause Aplause
odisea
odisea
Localización : Rubi
Mensaje  MERIDIAN Jue 9 Abr 2020 - 20:40
PVP recomendado:
4.799 €
IVA incluido
Aixxx, hay que leerse bien las características
https://www.supersonido.es/p/yamaha-a-s3000
Mensaje  poolside Jue 9 Abr 2020 - 20:44
MERIDIAN escribió:Aixxx, hay que leerse bien las características
Aixxx, hay que leerse bien los hilos.
Hablamos de los altavoces NS-3000, no del amplificador ya descatalogado A-S3000...
Mensaje  MERIDIAN Jue 9 Abr 2020 - 21:37
a
Aixxxxxx que poco veo ya. Disculparrrrr
Mensaje  poolside Jue 9 Abr 2020 - 21:50
Ya que estamos hacemos una porra a ver si acertamos el precio, Tente ha dicho 3.000 euros, yo creo que andarán por los 4.500 con soportes.
Mensaje  tente Vie 10 Abr 2020 - 0:16
poolside escribió:Ya que estamos hacemos una porra a ver si acertamos el precio, Tente ha dicho 3.000 euros, yo creo que andarán por los 4.500 con soportes.
Ah coño, que no pensé en los soportes, 1500€ leurus de soporte más Razz
tente
tente
Mensaje  xavi... Dom 19 Abr 2020 - 20:01
En What HiFi? especulan un precio de 8.000 £, la mitad que el modelo grande.
“We are awaiting price confirmation of the Yamaha NS-3000 bookshelf speakers, but we can expect them to wear a more wallet-friendly price tag than the NS-5000s, somewhere around the £8000 mark.”
Cantidad de envíos : 1402
Mensaje  tente Dom 19 Abr 2020 - 20:03
https://www.avpasion.com/yamaha-ns-3000-unos-altavoces-de-estanteria/
8-9.000€ Shocked
tente
tente
Mensaje  poolside Dom 19 Abr 2020 - 22:16
tente escribió:https://www.avpasion.com/yamaha-ns-3000-unos-altavoces-de-estanteria/
8-9.000€ Shocked
Aparte de la porra standard, dije 4.500 con soportes y seguramente me quedé corto, pero voy a hacer también una porra inversa:
Basándome en otros artículos escritos por la misma persona y que he visto llenos de imprecisiones y/o errores, voy a apostar a que: el sitio de donde ha copiado ese precio es una suposición de alguien que ha exagerado y finalmente no será tan alto. De mis 4.500 iniciales subo a 6.000 máximo con soportes (euros de venta en España, no libras). Puedo equivocarme, obviamente.
¿Alguien más se anima?
Mensaje  kerouack Lun 18 Ene 2021 - 11:51
Aún no se sabe precio ?
kerouack
Cantidad de envíos : 2102
Mensaje  tente Lun 18 Ene 2021 - 11:56
Veremos a ver el precio, pero como dice el compañero, cerca de los 6000€ seguro. Tendrán tan buenas críticas como las hermanas mayores ns5000?.
En su día me interesé por la serie Soavo y tampoco encontré mucha información.
tente
tente
