Audio Power Amplifier Design Handbook by Douglas Self
Audio Power Amplifier Design Handbook by Douglas Self Empty Audio Power Amplifier Design Handbook by Douglas Self
Mensaje  gizmo Lun 2 Sep 2013 - 10:03
Llevaba unos días intentando encontrar este libro on-line y al final he dado con el.
"Audio Power Amplifier Desing Hadbook" ya va por su sexta edición. Douglas Self, músico amateur, profesional a los mandos de mesas de control, psicólogo y especialista en psicoacústica edita este libro sobre amplificadores a transistores desde un prisma muy personal que difiere de lo hasta ahora editado anteriormente.
Lectura interesante hasta para los que como yo, no tenemos n.p.i de aspectos ténicos.
[url=http://www.qsl.net/kb7tbt/manuals/Ham Help Manuals/Audio Power Amplifier Design.pdf]http://www.qsl.net/kb7tbt/manuals/Ham%20Help%20Manuals/Audio%20Power%20Amplifier%20Design.pdf[/url]
No se por qué no funciona el enlace una vez puesto el link. Si copiáis la ruta y la pegáis directamente en vuestro navegador no tendréis problemas.
Un adelanto:
"The core of this book is based on a series of eight articles originally
published in Electronics World as ‘Distortion In Power Amplifiers’. This
series was primarily concerned with distortion as the most variable feature
of power amplifier performance. You may have two units placed side by
side, one giving 2% THD and the other 0.0005% at full power, and both
claiming to provide the ultimate audio experience. The ratio between the
two figures is a staggering 4000:1, and this is clearly a remarkable state of
affairs. One might be forgiven for concluding that distortion was not a very
important parameter. What is even more surprising to those who have not
followed the evolution of audio over the last two decades is that the more
distortive amplifier will almost certainly be the more expensive. I shall deal
in detail with the reasons for this astonishing range of variation.
The original series was inspired by the desire to invent a new output stage
that would be as linear as Class-A, without the daunting heat problems. In
the course of this work it emerged that output stage distortion was
completely obscured by non-linearities in the small-signal stages, and it
was clear that these distortions would need to be eliminated before any
progress could be made. The small-signal stages were therefore studied in
isolation, using model amplifiers with low-power and very linear Class-A
output stages, until the various overlapping distortion mechanisms had
been separated out. It has to be said this was not an easy process. In each
case there proved to be a simple, and sometimes well-known cure, and
perhaps the most novel part of my approach is that all these mechanisms
are dealt with, rather than one or two, and the final result is an amplifier
with unusually low distortion, using only modest and safe amounts of
global negative feedback.
Much of this book concentrates on the distortion performance of amplifiers.
One reason is that this varies more than any other parameter – by up to a
factor of a thousand. Amplifier distortion was until recently an enigmatic
field – it was clear that there were several overlapping distortion
mechanisms in the typical amplifier, but it is the work reported here that
shows how to disentangle them, so they may be separately studied and
then with the knowledge thus gained, minimised."
Cantidad de envíos : 5436
Audio Power Amplifier Design Handbook by Douglas Self Empty Re: Audio Power Amplifier Design Handbook by Douglas Self
Mensaje  electronauta Sáb 21 Sep 2013 - 8:11
Muchas gracias Gizmo.
Al fin he conseguido descargarlo, quitando el (URL) del final del enlace (infor-torpe que es uno)
Tiene miga y mucho que leer, así que a ello poco a poco.
Parece que nadie más se ha decidido a mirarlo o al menos comentarlo, así que como de bien-nacidos es ser agradecidos, gracias de nuevo.
Javier
electronauta
electronauta
Cantidad de envíos : 344
Mensaje  gizmo Sáb 21 Sep 2013 - 10:27
No hay de qué, Javier.
Llevo una semana que saco todos los días un hueco para echarle un vistazo. El potencial del texto está limitado por mis nulos conocimientos de electrónica de la forma más técnica pero de un tiempo a esta parte es algo que me mantiene ocupado con distintas lecturas.
Mensaje  jalejos Sáb 21 Sep 2013 - 12:15
Interesante libro con mucha información.
Gracias por el aporte.
jalejos
jalejos
Cantidad de envíos : 971
http://www.atm-audio.com
Mensaje  electronauta Sáb 21 Sep 2013 - 14:30
Yo voy por la página 24, pero creo que me voy a saltar páginas porque al principio se "enrolla" un poquitín con lo de la sicología y esas cosas.
Gracias de nuevo
electronauta
electronauta
Mensaje  gizmo Sáb 21 Sep 2013 - 23:20
Por la influencia de sus estudios y su dedicación profesional,consecuencia de su especialización en psicología y psicoacústica ,unida al dominio de otras disciplinas enfrentadas en la práctica, todavía lo hace más interesante por lo atípico del punto de vista que puede poner encima de la mesa.
El libro va por su sexta edición.
En foros especializados sobre electrónica "independiente" hay un hilo abierto por el propio autor para pedir opiniones al respecto de lo expuesto y sin entrar en la mayor validez o no, es objeto de extenso debate.
Si no recuerdo mal, la semana pasada iba por 139 pàginas en las que el autor interviene de manera regular.
El libro es un lujo porque desafía principios de la electrónica aplicada al audio que recogen conocimientos subjetivos capaces de ponerlos en entredicho.
Mensaje  gizmo Dom 22 Sep 2013 - 1:14
Dejo el enlace del hilo antes mencionado.
http://www.diyaudio.com/forums/solid-state/230492-audio-power-amplifier-design-book-douglas-self-wants-your-opinions.html
