Amplificador integrado híbrido DK Designs VS.1 Reference Signature Mk.III
Muy buen estado.
PVP: 3.300 euros.
Magnífica compra para el que quiera disfrutarlo por tan solo 750 euros.
Description: Two-channel solid-state integrated amplifier with tubes in low-level circuitry. Tube complement: two 6922. Maximum output power: 150Wpc into 8 ohms (21.8dBW), 300Wpc into 4 ohms (18.8dBW), both channels driven. Total harmonic distortion: <0.1% (1kHz) (level not specified). Frequency response: 20Hz–32kHz, ±1dB. Signal/noise: >90dB (reference level not specified). Channel separation: >60dB (1kHz). Input impedance: 47k ohms. Input sensitivity (for 1W into 8 ohms): line input, >200mV. Phono input: >4mV. Overload signal level: >2V.
Dimensions: 16.75" (430mm) W by 9.2" (235mm) H by 18.7" (480mm) D. Weight: 77 lbs (35kg).
PVP: 3.300 euros.
Alien Delon- Cantidad de envíos : 3638
» Duración valvulas amplificador hibrido.
» Magnat MA 1000 amplificador híbrido...
» AYUDA PARA ELEGIR UN AMPLIFICADOR HÍBRIDO
» Duda con amplificador hibrido Qinpu A-6000
» xDuoo TA-10: amplificador, DAC y previo de auriculares híbrido con buena calidad/precio
