Una grabación "a pelo" (con un equipamiento magnífico)
Y la aquiescencia de la banda.
https://www.dropbox.com/scl/fo/oyrsokuaw2odrdicf76nt/AFnvqcPrzCdwqYgLYPmalCA?rlkey=gz6nob60wanshditkp30da7bg&st=1cielwub&dl=0
Todo lo que nos dice el propio taper de esta grabación "a pelo", micro en mano, es rigurosamente cierto.... es excepcional.
Artist / Title: The Zawinul Syndicate
Date August 31, 1997
Seats: Table-36 (Dead Center)
Deck: Panasonic SV-255 (DAT)
Mics: Neumann KM-140
Source: DAT: Master Tape, 2-Mic Stereo
Sample Rate 48Khz, 16-bit (FLAC)
Rating: A+
Length: 86 Minutes
A Robert Collins Master Recording.
Musicians: Josef Zawinul Keyboards, Vocals
Gary Poulson Guitar
Victor Bailey Bass Guitar, Vocals
Paco Sery Drums, Kalimba, Vocals
Manolo Badrena Percussion, Vocals
CD1:
01 - Ochy - Bala / Pazyryk
02 - South Africa / Introduction to a Mighty Theme
03 - Waraya
04 - Patriots
05 - Sunday Morning - Sunday Evening
06 - Indiscretions
CD2:
01 - Asi Trabajamos
02 - Bimoya
03 - Band Introductions
04 - Zansa II
05 - Carnavalito
About this recording
Back when I introduced my Weather Report, 1982-06-01 recording, I said that it was probably the best Weather Report recording and concert you had never heard.
I will say the same about this one. This could be the best Zawinul Syndicate recording you've never heard, and after hearing it...might still be the best.
This is a recording and a show where every star in the universe aligned to make an almost flawless recording of a memorable event.
August 31st was a night where every star in the universe aligned to make the perfect recording of the perfect performance, this show absolutely burned the house down.
The playing was so good, so tight, and the vibe was so good this night. The band delivered an incredible performance, and the recording came out great.
The audience was perfectly behaved, and so quiet that you couldn't hear a single word or comment even during the quietest musical passage.
The recording itself is a solid A+ rating. To me, that means it sounds better than a commercial product. This recording is crystal clear, and has a full 60+ decibels of dynamic range.
No equalization or compression was added. I only made sonic edits to remove microphone noise, coughs, and sneezes during the most delicate moments.
Otherwise, this recording is exactly what I captured the night of the show.
Esta grabación y otras dos (FMs) las tengo subidas a Clandestino 2, aún me queda una en la recámara......
Salut,
Ramón
Es del mismo año pero NO el mismo concierto grabado por el taper.
Rating: A+
Length: 86 Minutes
Gary Poulson Guitar
CD1:
03 - Waraya
04 - Patriots
06 - Indiscretions
CD2:
01 - Asi Trabajamos
02 - Bimoya
04 - Zansa II
05 - Carnavalito
Salut,
Ramón
Scarletbegonias- Cantidad de envíos : 4162
A Pablito le gusta esta publicaciòn
» Esto es una grabación "a pelo" y es FANTÁSTICA
» Equipamiento para medición acustica de salas
» Psicodelia, Acid Rock y otros artefactos psicotrópicos.
» ZP ¡NI UN PELO DE TONTO!
» ¿Otra tomadura de pelo más?
