Tannoy Legacy Eaton
Tannoy Legacy Eaton  Empty Tannoy Legacy Eaton
Mensaje  Rafaviana Miér 6 Mar 2024 - 11:36
Hola, alguien sabe las medidas del tannoy eaton, en la web de tannoy sale que de profundidad es 27.8cm y en otras webs sale que la profundidad es 25cm.
Rafaviana
Cantidad de envíos : 1
Fecha de inscripción : 06/03/2024
Tannoy Legacy Eaton  Empty Re: Tannoy Legacy Eaton
Mensaje  luisbustilloojeda Miér 6 Mar 2024 - 16:36
Página oficial
EATON
System
Frequency response 40 Hz - 30 kHz ±6 dB
Recommended amplifier power 20 - 200 W
Power handling (IEC) 100 W continuous, 400 W peak
Sensitivity 89 dB (1 W @ 1 m)
Impedance 8 Ω
Components
Low frequency dual concentric 1 x 10" (254 mm) paper pulp cone with
twin roll impregnated fabric surround.
52 mm (2") edge wound voice coil
High frequency dual concentric 1 x 1.3" (33 mm) aluminium/magnesium
alloy dome with edge-wound voice coil
Crossover
Frequency 1.2 kHz
Type Bi-wired, hard wired passive, low loss
2nd order low pass, 1st order high pass
Adjustment ±3 dB over 1 kHz to 30 kHz shelving,
2 dB to -6 dB per octave over 5 kHz to
30 kHz slope
Enclosure
Type Twin distributed port
Connectors 5 x 4 mm 24ct Tannoy customized
binding posts
Dimensions H x W x D 543 x 376 x 278 mm (21.4 x 14.8 x 10.9")
Net weight 19.5 kg (42.9 lbs)
Construction 19 mm (3/4") MDF with plywood
internal bracing - heavily damped
Finish Walnut veneer and high acoustic
transparency nylon grill cover
Accessory Pack (included)
Bi-wire bridge connectors
Prestige wood wax
Carpet protectors
Rubber feet
Luis
P.d.podria ser,no lo especifica,con conectores, y por eso alguna página pueda especificar esos 25 cmts,sin ellos,
Pero yo me fiaría de la página oficial
Cantidad de envíos : 3734
Localización : santander
