Lector de CD Audi Análogue Fortíssimo o Un Rotel
Lector de CD Audi Análogue Fortíssimo o Un Rotel Empty Lector de CD Audi Análogue Fortíssimo o Un Rotel
Mensaje  Doversound Sáb 5 Feb 2022 - 19:21
Hola a todos!
Pues ando mirando el tema del lector de CD.
Mi primera opción ha sido mirar por el foro ideas y opiniones.
Entre otros me he apuntado varias opciones de Rotel, Denon y Yamaha.
Me ha asaltado la inquietud del mogollón de mandos y he mirado en el mundo de segunda mano si encontraba el reproductor de CD a juego con mi amplificador que opera con el mismo mando a distancia.
He encontrado por HifiShark alguna cosa en Italia y a un precio similar al de los lectores que he dicho antes.
Las especificaciones del lector Audio Análogue son las siguientes:
"...Fortissimo CD Player/DAC
The Fortissimo CD-Player / DAC is a device that integrates the most technologically advanced solutions both as for the CD playback as for the DA conversion. Solutions in both the digital and analog design, making it an absolute reference for its own product category. Besides the quality of the project, the choice of components and solutions applied thanks to technology and the experience of Airtech, allow to obtain sound performance and musicality not common to digital sources.
Technical description
CD-5010B CD mechanism specifically designed by TEAC for high quality audio applications. Digital input selection and sampling rate converter using a single integrated for SPDIF receiver (digital input selection and extraction of audio data) and Sample Rate Converter functions thereby reducing the jitter which would occur using two integrated for the same functions. Oversampling of the input signal through two separate clock generators with 44.1 kHz and 48 kHz (in order to obtain multiple frequencies than the entire input frequency), low jitter and noise and with separate power supplies and operating individually depending on input frequency sample rate.Possibility to set the sample rate of the output (from 44.1 kHz to 192 kHz) while the unit is working and find the best setup. DAC 32-bit / 192kHz Advanced Segment. USBDAC 24bit / 192KHz, Adaptive and Asynchronous mode, compatible with Windows operave systems and Mac OS X up to 10.9. Zero Feedback Output stage. Phone output. Remote control. Graphic LCD display..."
El bicho pinta así:
Lector de CD Audi Análogue Fortíssimo o Un Rotel Audio-10
Lector de CD Audi Análogue Fortíssimo o Un Rotel Fortis10
Está claro que comprar algo con cierto tiempo de uso y sin garantía es un riesgo.
os agradecería vuestra opinión.
Saludos!!
Doversound
Doversound
Cantidad de envíos : 323
Localización : Norte de África
Fecha de inscripción : 23/02/2014
Lector de CD Audi Análogue Fortíssimo o Un Rotel Empty Re: Lector de CD Audi Análogue Fortíssimo o Un Rotel
Mensaje  porcorosso Sáb 5 Feb 2022 - 19:47
Hola Doversound, veo que vas a toda velocidad, la paciencia en esto del audio es una virtud, a mi que soy fan de la marca me gusta todo lo que hace esta gente, pero quizás deberías asegurarte de como esta de salud, este unidad es del 2017 creo, es un buen aparato sin duda.
Quizá si te esperas un poco, te sale algo similar y más cercano.
Pero, estaría bien saber que tipo de música oyes.
Xavier
Cantidad de envíos : 2273
Localización : BCN/Catalunya
A Doversound le gusta esta publicaciòn
Mensaje  Doversound Sáb 5 Feb 2022 - 20:29
Si, me acelero... es un defecto que tengo...jejeje
Tienes toda la razón. La prisa es mala compañera a la hora de las compras...
Sobre qué escucho...
Precisamente ahora estoy escuchando algo que no existe en vinilo como tantas publicaciones musicales de los 90 y los 2000.. Yann Tiersen – Amélie From Montmartre, Variaciones sobre la banda sonora de la película.
He estado escuchando a Yeule por recomendación de Tidal y... no me entra.
He escuchado con atención otra banda sonora Dead Man Walking... No la conocía y me ha gustado mucho..
He escuchado el Ah um de Mingus
He escuchado lo nuevo de Keb' Mo' Good to be...
He investigado la discografía de Violent Femmes...
He investigado la discografía de The cat empire...
Y el Pablo Honey de Radiohead...
Eso del historial de reproducción de Tidal como ejemplo de un sábado cualquiera.
Doversound
Doversound
Mensaje  porcorosso Sáb 5 Feb 2022 - 20:40
Tienes alguna preferencia, algún estilo predominante, pop, jazz, rock, clásica???, eso podría acotar, de alguna manera, tu búsqueda de cajas y reproductores
Xavier
