Sanyo Plus Q50... Help!!!
Good Morning,
Audiophile greetings,
It comes on the way a Sanyo Plus Q50, however it does not come with the headshell to support the cell. I do not care about the situation because I have the Q25 that can also be applied in the Q50. However I have in mind I acquired a headset for the Q50 the problem is that I see myself distressed for such, I have already looked on ebay and the little that appears is already with included cell, had preference in acquiring without cell.
Can anyone help in this situation?
Already now some opinion for cell up to € 120 for the low mass arm?
best regards
Bruno Ribeiro
best regards
Bruno Ribeiro
Stinkfist86- Cantidad de envíos : 6
Localización : Portugal
Fecha de inscripción : 20/04/2018
Re: Sanyo Plus Q50... Help!!!
Maandee?
First, this is a spanish forum, and everybody writes in spanish. So although it is sure there are people who understand English, most people can't. I think it is even easier for us to understand portuguese.
About your problem, the headshell of that turntable, is an "ADC type headshell" for straight tonearms , you can search for it with that words, instead of searching for "sanyo q50 headshell".
These are some links where you can buy it:
https://www.ebay.es/itm/Original-Genuine-ADC-Headshell-for-Straight-Tonearm-ALT-1-from-1600-DD-Turntable/323831068843?hash=item4b65d5f8ab:g:rl4AAOSwtIZc~rPj
https://www.turntableneedles.com/LMH-1-Headshell-for-ADC-Compatible-Straight-Tonearms_p_4344.html
https://www.lpgear.com/product/PTS008.html
https://snvinyl.co.uk/ADC-type-straight-arm-headshell
psychoart- Cantidad de envíos : 639
Localización : Valladolid
psychoart escribió:First, this is a spanish forum, and everybody writes in spanish. So although it is sure there are people who understand English, most people can't. I think it is even easier for us to understand portuguese.
ola psychoart
Lo siento por la escritura inglesa
Muchas gracias por los comentarios.
He verificado que has enviado este enlace.
Puedes decir la diferencia al equipo en este enlace?
https://www.turntableneedles.com/Straight-Tonearm-Headshell-for-Many-Japanese-Turntables_p_785.html
Las medidas son diferentes
Tengo miedo de comprar el casco incorrecto y no puedo sintonizar correctamente la celda
Desafortunadamente, el Sanyo Plus Q50 que compré no tenía cabeza
Es el brazo del Sanyo Plus Q25 Ttambem un tipo ADC?
Pues eso no lo sé, en el manual del Plus Q50, especifica un overhang de 15mm, prueba con el headshell del q25, y si puedes conseguir ese overhang, compra una que mida lo mismo que la que tienes.
» Sanyo TP 350
» Sanyo Mr 210 problema en el arranque
» Magnetofón Sanyo RD2310
» Amplificadores Sanyo 1976
» Amplificador Sanyo y entrada de video
